problem with staged injection
Barton
Post by Barton »
firmare 1.4.1
setup EVO 9
oem 550cc + FIC 2150cc
6466
kelford 280R
10.5:1
for now testing with 98 octanes
the mivec is not working right now, I already requested this feature.
with the primaries the engines runs great, but when turn the staged injection on the afr goes lean when the secondaries are activated,
I tested with gradual transition with no luckk.
here are the log and the msq
evo stage injection problem.msq
(276.23 KiB) Downloaded 27 times
test1.msl
(52.78 KiB) Downloaded 27 times
test2.msl
(61.7 KiB) Downloaded 22 times
Megasquirted engines: 4g63, k24a2, b16-b18, duratec, ecotec, fiat 8v-16v, modular 4.6 32v, 1fz-fe, fiat 5cil 20v, Opel corsa, G54B, VW AG, 2ZZ-GE.
https://www.facebook.com/Bartonefi
instagram: @bartonefi
arran
Re: problem with staged injection
Post by arran »
Is there anything stopping you from upgrading to the current latest, 1.5.1?
I think the general recommendation is to use table based staging rather than map based. My staged injector setup in a rotary is shown in the picture. 1000cc Primary and 1000cc Secondary injectors
http://web.aanet.com.au/arran
Barton
Post by Barton »
the problem is solved, but I wondering how to know what should be the injection timing for the secondaries?
I'm using a magnus v5 intake manifold with 550cc as primaries and 2150 fic injector as secondaries
