Cant get a good sync on my honda s2000
I'm trying to set up my megasquirt v3.00 with ms3x to run my s2000, i've got the adaptor harness wired up and tunerstudio seems to get the expected crank and cam timing data (using the logger), 4-1 on the cam and 12 teeth on the crank, and it does briefly sync and start the fuel pump but then loses sync for probably 3/4 of the rev. I'm attempting to run the rc51 code. I also can't find the option to run 4 cylinder even fire but i'll cross that bridge when i get to it.
- Attachments
- 2017-10-13_17.48.41.csv
- (21.21 KiB) Downloaded 22 times
- s2000 logggg.png (226.09 KiB) Viewed 329 times
- (21.21 KiB) Downloaded 19 times
Re: Cant get a good sync on my honda s2000
Didnt seem to upload on first attempt so here goes
Can't seem to upload my msq, any reason for this?
Want a guess? I don't think you can upload an MSQ as the "current tune" in your project file. You have to save the MSQ with a distinct name and upload that saved one.
That's the answer, not been messing with my megasquirt long... will upload tomorrow
here's the msq finally, tried swapping the cam signal over to the other cam but no luck yet
- Attachments
- s2000-1.msq
- (283.91 KiB) Downloaded 33 times
https://youtu.be/7VF3auKz7GM
a video capture of an attempted sync
i've messed around with the pots and have a new short trigger log for you to view
- Attachments
- 2017-10-15_13.21.15.csv
- (20.09 KiB) Downloaded 24 times
I'm not going to be able to help, I know nothing about that specific Honda trigger system. I'm a simple "missing tooth" guy...
Had a look through as many .INI files as I could find and can't find where any of the information about the trigger wheels is kept (I'm hoping that may shed some light on my sync issue) but can't find anything related to the rc51 wheel decoders.
Spkmode_0 is mentioned with almost every other number after it (I think from the table I should be looking for spkmode_0 == 30? I'm not sure on that though). Are all the trigger wheel decoders saved in tuner studio rather than the firmware files?
Why can't this be written in arduino? Ha.
Looks like the rc51 code won't ever run my s2000, i didnt realise the 3 pins on the trigger wheel weren't 90 degrees apart
http://www.msextra.com/doc/triggers/Tri ... 0RC-51.JPG
On the s2000 all 3 teeth on the cam trigger wheels are 90 degrees apart, with 180 degrees being plain.
I don't know how much work it would be to make another trigger mode for the s2000?
I presume the crank/cam sensors are attached to interrupts? For the crank interrupt could it be possible to add a second function that counts crank teeth but the second one gets reset by the cam interrupt, then add an operation to the cam interrupt to check the number of crank teeth since the last cam interrupt, then add a flag along the lines of when "if crank teeth since last cam signal> 11 (12 tooth crank wheel) then the next cam interrupt resets both the crank counters"
Or is that too much code to be processed by the hardware.. i know arduino wouldn't handle it but I don't know C or the ms hardware.
(crank interrupt)
maincrankcounter ++
secondcrankcounter ++
(cam interrupt)
if secondcrankcounter>11 maincrankcounter=0 secondcrankcounter = 0
else secondcrankcounter=0
Syntax miles out but something like the above..
(crank interrupt)
maincrankcounter ++
(cam interrupt)
Orrrrrr
crank interrupt normal
cam interrupt
secondcamtoothnumber ++
if secondcamtoothnumber>3 (firstcamtoothnumber ++)
might be more simple to program... who knows?
second edit.. this one wouldnt work..... first one might still though
cam interrupt
