no sync after 3 yrs of running great
Re: no sync after 3 yrs of running great
R66 is the pull-up resistor for the MS3X CMP input; maybe needed if the CMP sensor is Hall. It should have already been on the 3X board and is enabled by installing jumper JP7 on the board.
I wired in a Honeywell gt101 hall effect sensor this morning and I no longer have a hesitation at 1500 rpm. The cam pickup had to be changed from risiing to falling edge to keep the cam signal from falling on one of the crank signals. I suppose I have to check the timing now. The comp log has no sync errors. The idle is still quite rough. Any suggestions would be welcome.
- Attachments
- 2017-11-01_11.38.32.msq
- (191.86 KiB) Downloaded 37 times
- 2017-11-01_11.32.26.msl
- (278.28 KiB) Downloaded 39 times
