Hi! I quite correctly understood this feature ( New / changed features:
Add command buttons for ‘Stop Engine’ and ‘Reset ECU’) need to start and stop the engine with the buttons on the screen I use the latest firmware MS3 pre-1.5.1 beta 1 firmware & TunerStudio MS Ultra v3.0.28
Where can I find this function In the TunerStudio I looked TunerStudio and no button stop engine and reset ECU I hope I understood correctly that there is a function in MS TunerStudo start-stop motor on the touch screen of my Car PC Say thank you for the help if you show me where it is
TunerStudio New changed features: Add command butt
Re: TunerStudio New changed features: Add command butt
No, this is nothing to do with TunerStudio.
The firmware supports shutting down the engine. The two buttons are available on the "Engine Control" page on the CAN/testmodes dropdown menu.
OK! Thank you ! I'll do it as soon as I can get to my car . Button can only stop the motor . Can TunerStudio developers in the future to assign a free pin output on the ECU so that I could assign an open port on the ECU, and do a relay control engine start with push button screen ?Or is it possible to write a plugin for that java?
