Hello guys...I've been working on this build now going on 2yrs ....I'm having a problem with sync errors ...I had it looking good in the logger...injectors and coils were firing so had RPM...Now I'm getting a lost of signal ....Would someone PLEASE have a look at these logs for me ...I've been reading and reading and going crazy now..lol..
The motor is a 4.8 24x with a ls9 cam running e85 "trying to run" with Megasquirt 3 with ms3x
The 1st 2 logs when it tried to run last 2 when it went weird
I think there in the right order...I dropped my lap top and I'm using my wife's...lol
Thanks for any help
At a loss here...Please help.....
- Attachments
- 2017-10-28_10.50.16.msl
- (291.09 KiB) Downloaded 22 times
- 2017-10-28_10.02.13.csv
- (10.72 KiB) Downloaded 21 times
- 2017-10-28_11.00.25.msl
- (200.23 KiB) Downloaded 16 times
Re: At a loss here...Please help.....
Post the MSQ and a tooth-log.
Ok everyone disregard the 1st post ......After a ton more reading and some more reading after that....I adjusted the pots some more then I found I didn't add enough fuel for the cranking then had to add fuel to ASE ....Well I'm running now but the idle is to high now....I also have a AEM 30-0300 wideband O2 in the car but not wired to the MS3....for that I used just a factory 4.8 narrowband and it doesn't look right in a log...That's got something to do with the idle too...
Can the AME work with the MS3?
Here's the last log I did tonight ....please have a look and give me some input...Thanks guys
- Attachments
- 2017-10-29_20.07.19.msl
- (106.48 KiB) Downloaded 19 times
