I use ve1 table as MAF correction table.
Is the displayed and logged MAF with or without correction table applied ?
Re: MAF correction table
1. So do I.W126 wrote:1. I use ve1 table as MAF correction table.
2. Is the displayed and logged MAF with or without correction table applied ?
2. I would say "without". The MAF value is an input (g/sec) & cannot be changed.
I assume without too.
But I want to know for sure.
