Help! Engine will not turn off with key, sometimes. MS3 Gold Box
I have have had an engine run-on issue that has come and gone on my car. It went away completely for about 2 months and just recently showed back up. About 50% of the time the engine shuts off with the key, the other 50% the engine will continue to run. Sometimes I can turn the key on/off several times and it will die, sometimes that doesn't work. It's very inconsistent.
When the engine runs-on my ECU is seeing 8.0v, somewhere I am getting a backfed source of power that is knocked down from the battery. I verified that by powering the voltage regulator with the engine running on and the 8.0v went up to 9.5v.
What I know:
*When the engine is running on*
- 8.0v to the ECU and control side of fuel pump and inj/coil relays
-Engine will run "forever" in this state, the 8.0v is knocked down from the battery. Somewhere.
- I can pull the main relay, car still runs, see note in attachment.
- Sometimes I can toggle the ign switch on/off and it will die.
- I have completely disconnected the ignition switch, it has nothing to do with the issue, from what i can tell
- It typically happens after the engine has been idling for 1+min
- If i pull the 20a inj/coil fuse the engine will die [obviously], but the 8.0v *goes away* and the ECU will go offline
-If I pull the fuel pump relay, the engine runs itself out of fuel [on 8.0v]
- I can rev the engine and it will die
- I can open the alt charging circuit to the battery, it has no effect. I have not removed alt field wires, the field is divorced from the rest of the car with the key off. [no charge light]
I wired up the car completely from scratch and I like to think that I am pretty savvy at wiring. This one has got me baffled!!!! For now I have worked around it with a tableswitch with RPM and battery voltage <9.0v. But I hate having to do that.
Problem - MS3 Engine Run-On with Key Off
MS3 Gold Box, TunerStudio MS/MegaLogViewerHD user
Re: Problem - MS3 Engine Run-On with Key Off
If you make the main relay supply the power for the rest of the car, e.g. for the injectors and for the fuel pump, rather than just for relay coils, then no ignition switch will mean no 12v to the injectors or fuel pump.
The alternative approach is to put diodes across relay coils, so they cannot be backfed.
kind regards
Marek
kind regards
Marek
Do you have any other relays or solenoids connected to the ECU ? Where do they get their 12V from?
have you got any fans operating that run off the ignition switch?
Hey, I don't know if this will help you, but I had the same issue with my MS3X installation. The only way to get the engine to stop was to disconnect the main relay. I found out that the alternator can feed power back to the Megasquirt's main relay and keep it energized. I needed to add a diode from the alternator to the warning light in my dash. I have a '73 Volkswagen which has stupid simple wiring, but this can be commonplace with many aftermarket engine management systems and vehicles. See the attached for more information. I used the 1N4001 as indicated and it immediately solved the issue. Hope this helps.
Your problem lies in the secondary relays getting their +12v for the coils off of the same wire that supplies +12V to the MegaSquirt. The MegaManual specifies a dedicated relay for the MS switched power input which prevents if from back-feeding power.
2011 Kia Soul
G4GC + 5 Spd
MS3x in progress
G4GC + 5 Spd
MS3x in progress
