i have MS-pro installed on BMW M50 engine running 60-2 crank wheel and half moon hall cam sensor , i have always a 2 pulse cam sensor and the car give cam fault and do not run sequential mode , whatever setting i do it do not work , rising,falling,poll level. nothing work
i attached a tooth logger log to show my tooth pattern
BMW M50 Cam sensor fault
- Attachments
- cam tooth logger.csv
- (115.6 KiB) Downloaded 34 times
Re: BMW M50 Cam sensor fault
This looks like it ought to work on one edge even with it giving two pulses. Can you post the MSQ?
the cam sensor is hall effect , and the cam tooth is half moon
- Attachments
- Basemap.msq
- (272.76 KiB) Downloaded 48 times
esso
i got the same thing with my M62
that is a 4 tooth cam triggerwheel
but what happens if you change in the "Ignition settings", "spark mode" from Toothed wheel to Log crank&cam?
see my tooth log's in the attach
- Attachments
- log crank and cam.png (125.95 KiB) Viewed 508 times
- log cranking.png (109.61 KiB) Viewed 508 times
