Vats integration
Vats integration
Would it be possible to use an existing GM Vats system with a MS3+3x setup. The output for a good reading is a 30hz square wave but I am unsure of the voltage. The goal is to replicate the feature built into all 90's GM cars with a resistor chip where if you try to start the car without a proper reading in the ignition the car will not activate the fuel pump. The module will also prevent the starter from activating but that is not connected with the PCM.
94 Pontiac Firebird Formula
5.7L LT1 (optispark)
Ms3+3x
Ms3+3x
