Hello,
I am having some trouble with tuning in an M52 engine. It's hunting really bad, even though I set everything at one specific value.
Keep in mind this is in fact my first full sequential build
850cc injectors à là chineesium, Turbo, stock internals, stock everyting else...
BMW M52 Hunting like crazy
- Attachments
- M52TUB28.msl
- Log file
- (117.75 KiB) Downloaded 48 times
- M52TUB28.msq
- Tune
- (274.67 KiB) Downloaded 49 times
Re: BMW M52 Hunting like crazy
Either the wideband isn't working, or you're running pig rich.
Normally an M52 would have a three wide IAC valve - has this been swapped for some other part?
Running a seperate innovative mtx afr gauge.
The idle valve is swapped to a 2 lead spring returned style. Sorry, i forgot to add.
Wiring the MTX-L to the ECU will give you a lot more tuning data.
