Hello,
[Time-Based accel] & [Accel-Pump accel], I tried both settings.
[Time-Based accel] could not be worked.
[Accel-Pump accel] could be worked.
Why can not I use [Time-Based accel] ?
Accel enrich settings:Time-Based accel could not work
- Attachments
- 2017-11-11_16_Pump-accel.msl
- Accel-pump accel-log
- (1.02 MiB) Downloaded 29 times
- 2017-11-11_16_Time-accel.msl
- Time-accel accel-log
- (1.25 MiB) Downloaded 32 times
- 2017-11-11_16.20.24.msq
- (285.31 KiB) Downloaded 32 times
MAZDA MX-5 Roadster Turbo with DIY FRP inlet piping & DIY V-mount Inter cooler
MAZDA MX-5 Roadster NA8C 2-liter + VVT & Quadruplicate throttle
Daihatsu Mira LE-L250V 3Cyl. 'Petit' Miller cycle + 'Petit' Lean burn + Turbo + VVT 660cc 690Kg
Suzuki Kei GF-HN21S K6A Turbo 3Cyl. 660cc 740Kg
Re: Accel enrich settings:Time-Based accel could not work
I use time-based accel with 100% TPSdot blend with no problems. Could it be because you are mixing 50% MAPdot and TPSdot?
Martin, Sweden
Mopar 512 cui, 8.4 liters, high compression, fuel E85, full sequential control by MS3X, burning rubber just blipping the throttle...
Thank you for the advice.
I think that it will make sure that the function of [Time-Based accel] works under [100% TPSdot blend] condition.
But [Time-Based accel] menu screen has [MAPdot & TPSdot] blend function.
[Accel-Pump accel] could be worked under [MAPdot 5% & TPSdot 95%] blend condition..
Is not it strange that [Time-Based accel] will not work if it be blended ?
The strange thing is they are both time based. They should really get rid of the time based accel as it is buggy and doesn't work well. The ACCEl-Pump enrichment works so keep that one.
