idle air controler pintle manual adjustment
Postby flatbill » Sun Nov 12, 2017 11:15 am
I have had an MSII running a TBI on my '56 Desoto motor and am now working on getting an MSIII system with port injection, sequential fuel and spark. I now have a 4 bbl throttle body that uses the O ring 2 mounting screw 4 wire IAC. I bought a new IAC. Now I find that the pintle is extended too far to install it in the throttle body. I suppose it is possible to manually retract the pintle. I have tried rotating the pintle tip but I am leery of turning it very hard. It does not rotate freely. How much force is needed and in which direction to retract the pintle? Thanks. Billk
flatbill
Re: idle air controler pintle manual adjustment
Postby billr » Sun Nov 12, 2017 6:01 pm
There is no easy way to manually retract those pintles. Your best bet is to connect the IAC and use "test mode" to move it. I have been able to move pintles in by wiggling them around in a circular motion, like stirring a drink straw, while pushing in gently. They do not just screw in, don't try to force it. In fact, it should not rotate at all.
billr
Return to MS3 General Support
