Miata.lean hot restart
nismoautoxr
Post by nismoautoxr »
This is a 97 miata witg an 02 vvt engine, 650cc diyat highz injectors and a t3 intercooled turbo. I do not have a log of it right now but here is what happens. If it sits for about 15 minutes after a normal drive.....it is extremely lean on the restart to the point that it might stall out after starting it unless I rev it a few times. I dont feel that its mat correction because I set everything above 70degrees to 100 so it shouldnt be correcting for mat at all so why on earth is it lean on hot restarts? Im going to get a log but so far I havent caught it but it is like 17 to 1 untill it runs a couple minutes. Is anyone else having this problem?
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MegaMicra
Re: Miata.lean hot restart
Post by MegaMicra »
Can you not set the after start enrichment to cover this lean period. That's all I do.
Sent from my WAS-LX1A using Tapatalk
NigeT
Post by NigeT »
I have very similar issues with my NA8 MX-5. Once bit it goes lean shortly after engine start, maybe ager my ASE has tapered off.
Sent from my SM-N950F using Tapatalk
nismoautoxr
MegaMicra wrote:Can you not set the after start enrichment to cover this lean period. That's all I do.
Yes I can but the amount of afterstart enrichment and the taper time needed is a moving target ....i.e. dependant on the amount of time it sits before the restart. Sometimes its appropriate and sometimes its too much for too long, if that makes sense.
Im confident that its not an iat placement problem. The iat is in the cold side intercooler pipe about 4 inches prior to the trhottle body. Its a gm open element sensor. Besides that....I went into the tune and set everything above 70 F to 100% on the air density correction so it should be removed from the equation. I dunno wth is going on . Idk if the fuel is getting hot in the rail ....has some intermittent pressure issue....some goofy injector issue...idk. No other evident problems outside of that are going on while driving it.
I used to have a similar problem with my 240 sx back when it had a microsquirt module in it but all that went away when I put the ms3 in it. The LS2 engine didnt hurt either lol. I digress. Its embarrassing and irritating to try and leave somewhere and the car start and stall 2 times and surge at idle for amcouple minutes. I just wanna get to the bottom of tgis and fix it.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MegaMicra
Post by MegaMicra »
Could it possibly be heat soak of the inlet manifold causing the fuel to vapourise on restart. I know some of the rally guys over here use ptfe spacers between the head and manifold to stop this.
nismoautoxr
MegaMicra wrote:Could it possibly be heat soak of the inlet manifold causing the fuel to vapourise on restart. I know some of the rally guys over here use ptfe spacers between the head and manifold to stop this.
I suppose it could. Its all stock stuff aside from the higher flow injectors and the turbocharger. I just street drive the car to work and around town and stuff. Im not sure exactly how to conclude if that is the cause. Ill have to think on that.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
arran
Post by arran »
Have you not deliberately created this issue by levelling out the MAT correction? The configuration you have implemented is going to cause the behaviour you are seeing.
My experience with the default curve is that it is too aggressive even though it is setup to model gas law. In reality it had a leaning impact on fuelling on a hot day in my part of the world.
If I was you I would try reinstating the did fault curve but halve all the values so the S is much flatter
http://web.aanet.com.au/arran
nismoautoxr
arran wrote:Have you not deliberately created this issue by levelling out the MAT correction? The configuration you have implemented is going to cause the behaviour you are seeing.
Im not completely sure if u saw all that I posted but ive taken every bit of mat correction out of the equation by setting everything above 70*F to100%...that means any mat above 70 has no affect on the actual afr.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
arran
Post by arran »
I guess what I am saying is that the MAT correction exists for a reason. Your curve sounds like it is incorrect. This is what has been working for me:
DNMakinson
Post by DNMakinson »
Extra ASE is the correct answer. That and allow EGO to be active at the idle area.
The coils of the injectors get hot, raising their resistance, and therefore decreasing magnetizing current, and therefore increasing dead time. It is a known phenomenon with many, if not all, HiZ injectors.
The range of idle AFR is great, with more tolerance toward rich than lean. Therefore, set your ASE for your worst case lean condition, and let things be rich for the short amount of time before EGO kicks in; on those occasions that the heat soaking of the injector coils does not occur.
I agree that 15-20 minutes of sitting is the worst case.
Lastly, set your ASE taper to work off Cycles, not seconds. That way ASE goes away more quickly when you rev the engine (or start moving) than when you crank and sit. You have already verified that things get better with revs, so this is the sensible approach to not maintain the extra fuel under that scenario.
