4cyl sequential with staged injection
I'm wanting to know how I set my secondary injectors so they correspond with the correct cylinders running sequential and staged injection. Thanks
Re: 4cyl sequential with staged injection
What's the firing order?
Although question is about ignition I sort of wonder if I set my sequential VE tables correctly. Certainly it would not be by ignition sequence?
Does Ve table 1= cyl 1
Ve2= cyl 2
Ve3= cyl 3
Ve4= cyl 4
Ve2= cyl 2
Ve3= cyl 3
Ve4= cyl 4
Toyota MR2 98 3sgte
MSPNP2 with 3.57 mainboard
TD05SL2-18g with external WG
HKS EBC running 17psi boost.
Not on MS3 no. Use the per-cylinder trim tables.benckj wrote:Although question is about ignition I sort of wonder if I set my sequential VE tables correctly. Certainly it would not be by ignition sequence?
Ve2= cyl 2
Ve3= cyl 3
Ve4= cyl 4
