Pre-Start Sanity Check MS3X
okubricko
Re: Pre-Start Sanity Check MS3X
Post by okubricko »
I just wanted to verify that my timing is retarded and not advanced.
billr
Post by billr »
I'll assume the "fixed" mark is at that red line that was added to the photo; at the right-hand edge of the tab cast into the block. But, which way does the crank turn in that photo, CW or CCW? The easy way is to set "fixed timing" at zero for checking with the light, then direction of rotation doesn't matter...
okubricko
Post by okubricko »
I should have been more clear. The red line on the picture is a split in the case that indicates TDC. If everything were perfect the red line would be right on TDC of the degree wheel. The engine rotates clockwise.
okubricko
Post by okubricko »
Success, I was able to get the car to fire and idle yesterday. :yeah!:
Thanks everyone for their help.
