Clutch management with PWM?
Postby mjhillen » Thu Nov 30, 2017 10:24 am
Is it possible to set up a PWM circuit with an ON delay and variable frequency output to control clutch lock-up operation?
I want to set it up to operate when the launch control is released.
I posted in the development forum but haven't had any response.
2004 Harley Road King TURBO 200+hp
mjhillen
Re: Clutch management with PWM?
Postby vw_chuck » Fri Dec 01, 2017 1:34 pm
Your talking about a PWMable valve that operates at 1000's of psi. Good luck finding that. It is much easier to put an orifice or bleed valve inline to slow the flow down.
vw_chuck
Postby mjhillen » Mon Dec 04, 2017 12:25 pm
vw_chuck wrote:Your talking about a PWMable valve that operates at 1000's of psi. Good luck finding that.
I dont need "1000's". I have a 480# clutch spring. My slave cylinder diameter is 1.75'. That's about 200PSI. I think i can find something.
mjhillen
Postby jeffmarsh750 » Sun Dec 17, 2017 7:49 pm
You could use a line lock solenoid, a solid state relay and an MS output to control it. Push clutch pedal in, push button to hold, meanwhile full throttle, release button and PWM release of clutch. WALA. How some bikes do it with a delay box.
jeffmarsh750
Postby mjhillen » Thu Dec 28, 2017 3:28 pm
i am thinking about using a 3 axis accelerometer and running it through a table to calibrate the response.
mjhillen
Return to MS3 General Support
Users browsing this forum: Bing [Bot], Lyonz and 2 guests
