Page 1 of 1
Clutch management with PWM?
Posted: Thu Nov 30, 2017 10:24 am
by mjhillen
Is it possible to set up a PWM circuit with an ON delay and variable frequency output to control clutch lock-up operation?
I want to set it up to operate when the launch control is released.
I posted in the development forum but haven't had any response.
Re: Clutch management with PWM?
Posted: Fri Dec 01, 2017 1:34 pm
by vw_chuck
Your talking about a PWMable valve that operates at 1000's of psi. Good luck finding that. It is much easier to put an orifice or bleed valve inline to slow the flow down.
Posted: Mon Dec 04, 2017 12:25 pm
by mjhillen
vw_chuck wrote:Your talking about a PWMable valve that operates at 1000's of psi. Good luck finding that.
I dont need "1000's". I have a 480# clutch spring. My slave cylinder diameter is 1.75'. That's about 200PSI. I think i can find something.
Posted: Sun Dec 17, 2017 7:49 pm
by jeffmarsh750
You could use a line lock solenoid, a solid state relay and an MS output to control it. Push clutch pedal in, push button to hold, meanwhile full throttle, release button and PWM release of clutch. WALA. How some bikes do it with a delay box.
Posted: Thu Dec 28, 2017 3:28 pm
by mjhillen
i am thinking about using a 3 axis accelerometer and running it through a table to calibrate the response.
