Ms3pro evo Coyote wiring help
Postby techno » Tue Dec 05, 2017 6:19 am
Hello! Please help with the coyote connection. I learned the manual, but I'm afraid of something to burn and do not really understand what channels to feed the sensors by their type. If someone has a similar connection experience and you will not be difficult to make the wiring diagram, I will be very grateful. Or tell me, there can be a suitable connection scheme for me from the manual
techno
Re: Ms3pro evo Coyote wiring help
Postby KAT PWR » Tue Dec 12, 2017 7:56 pm
which components are you concerned about wiring up? honestly, a quad cam motor with variable valve control is not an easy motor to wire up for a novice, but Im curious if you can run it with MS and would like to help you.
KAT PWR
Postby wes kiser » Wed Dec 13, 2017 8:13 am
KAT PWR wrote:which components are you concerned about wiring up? honestly, a quad cam motor with variable valve control is not an easy motor to wire up for a novice, but Im curious if you can run it with MS and would like to help you.
MS3 firmware supports coyote 4 cam VVT. I did one with a gold box plug and play a year ago. Worked great.
wes kiser
Return to MS3 General Support
Users browsing this forum: Bing [Bot] and 3 guests
