MS3Pro Ultimate 1.5.1 AFR/EGO Control Active Below Load(%)
TonyR85
Post by TonyR85 »
Maximum value I can enter in "AFR/EGO Control Active Below Load(%)" is 300kpa.
I'm setting up a car with 8 WBO2 and will exceed 300kpa and would like to keep closed loop active above 300kpa. Whats the work around?
Map sensor is configured as internal 4 bar. Is there a limit somewhere else thats holding me back?
Thanks,
Tony Reiners
Valeriy
Re: MS3Pro Ultimate 1.5.1 AFR/EGO Control Active Below Load(
Post by Valeriy »
I'm also interested in this! I join the author.
Reverant
Post by Reverant »
Same here.
The man behind MS Labs
nathaninwa
Post by nathaninwa »
Look under the general tab, near the bottom is a gauge limits setting. This may or may notnhe it
I know it affects rpm stuff and how far the ve table will be extended to
TonyR85
Post by TonyR85 »
nathaninwa wrote:Look under the general tab, near the bottom is a gauge limits setting. This may or may notnhe it
Max Load in General settings is 400kpa. It must be in the code.
Can anyone offer assistance or should I move this over to the development section?
Thanks,
Tony
nathaninwa
Just tried on mine. It's an INI deal.
racingmini_mtl
Post by racingmini_mtl »
Open the ini file and look for this line:
Code: Select all
      MAPOXLimit      = scalar,  S16,    168,             "%",      0.10000,   0.00000,  0.00,  300.00,      2 ; * (  2 bytes)
Change the 300.00 for the maximum you want. Please note that I have no idea how the code will behave with a higher value. Use at your own risk.
TonyR85
Post by TonyR85 »
racingmini_mtl wrote:Open the ini file and look for this line:
Code: Select all
That did the trick. Thank you!
nathaninwa
What control box will you be using for your wodebands?
Reverant
Post by Reverant »
Changing the ini doesn't solve the issue, once you upgrade to 1.5.2 or whatever the newer version will be, the limit will be restored back. The same is true if someone else plugs in with his own laptop. This needs to be addressed with an official ini change.
TonyR85
Post by TonyR85 »
nathaninwa wrote:What control box will you be using for your wodebands?
8x Innovate LC-2's to a CAN-EGT Box
-Tony
nvr2fst
Post by nvr2fst »
-Tony
Let me know how well this works for you. I have 8x setup on 2x 4 channel AEM and I am having a lot of closed loop control issues with big injectors and high HP. I can't really get the system to react fast enough.
racingmini_mtl
Reverant wrote:Changing the ini doesn't solve the issue, once you upgrade to 1.5.2 or whatever the newer version will be, the limit will be restored back. The same is true if someone else plugs in with his own laptop. This needs to be addressed with an official ini change.
Yeah, that was offered only as a work around. But it is also not a bad idea to have someone try it and see if the current code can cope with that or if there is also a need to tweak the code. Then an official ini change (with a possible code change) would make sense.
If you personally have experience that this does work fine with the current code then you should post a change request and say so. I'm afraid that what nvr2fst mentions above would be a limitation at those high boost levels. But in any case, I'm not an MS3 developer so that's not up to me.
nathaninwa
-Tony
Are the innovates pressure compensated?
Reverant
Post by Reverant »
Yes, I have tested it above 300kPa, and it works just fine, it's only an ini limitation.
TonyR85
Post by TonyR85 »
-Tony
They are not. I'm using them in a supercharged application.
-Tony
