MS3Pro Intermittent Shutdown
kenjfox
Post by kenjfox »
MS3Pro on Miata 1.8 VVT engine. The ECU appears to periodically shuts down, often after going into boost, but has also stopped after idling. There is no indication in the logs of a sensor or configuration problem. However, a recent log showed an offline/online/reset event.
From 2017-12-09_14.33.42.msl
Offline Event.png (33.66 KiB) Viewed 319 times
EDIT: Now learned this is a MegaLog Viewer display option. We've verified good grounds, and replaced battery just to rule things out. Any advice on further troubleshooting would be greatly appreciated. The ecu worked fine for months, by the way.
Catfish Tune.msq
(217.33 KiB) Downloaded 30 times
Catfish.zip
Logs showing sudden shutdown
(556.88 KiB) Downloaded 32 times
Re: MS3Pro Intermittent Shutdown
Post by Matt Cramer »
If this is an MS3Pro PNP, EVO, or Ultimate, check if the power lights are still on when it shuts down.
If it's a Gen 1 MS3Pro, you'll need to check for voltage on VREF instead.
This will give more clues about what's gone wrong.
w.tungsten
Post by w.tungsten »
Hi was this ever resolved? I'm having a similar issue with an MS3Pro Evo. I assume the resolution will be the same between ours.
**EDIT in our instance the issue was low resistance spark plugs. This lead to severe interference to the ECU. RPM spikes, dropouts and ECU resets were resolved as a result of changing spark plugs.
