I've got my idle stable at 13.5-13.8 and down to my target but anytime I add a load it starts surging 200-300 rpm. Today, I changed from adding ignition time at the leftmost column to stabilize idle, to using idle advance and idle correction curve. now the idle is always stable with no load and no longer will stall while surging. looking PWM Idle Duty its it'll swing up to 9% which is a lot of air with my BMW Bosch idle valve. I feel like the idle closed loop is overreacting with this large idle valve, wide open it can idle +4000rpm. So my question is, how do I go about taming the Closed-loop idle PID?
test drive log and msq
https://www.dropbox.com/s/ul6tn1yqswfmb ... e.zip?dl=0
oscillating idle
Re: oscillating idle
First, I'd get the spark and fuel tables dialed in so that it has a steady idle in open loop without idle advance correction. See if you can get good results with that, then switch closed loop back on.
I have found that you have to get the timing and PW stable to get the idle to calm down. Once stable, you can start playing tricks.
Not exactly this topic but see https://www.youtube.com/watch?v=XSyeko0-etk
Andy
Andy
Leave the IAC off for now and tune to a stable and slight high idle. Use timing to bring the idle sped down, slightly, and it will take load better.
Fwiw mine seems to idle best around 13.0AFR
1972 Plymouth 'Cuda - 5.7L Hemi w/T56 Magnum
MS3 Gold Box, TunerStudio MS/MegaLogViewerHD user
