Engine won't start
Engine won't start
Postby James » Thu Dec 28, 2017 5:06 am
Hi all,
Engine ran fine a couple of months ago. It's got colder here — but I don't think that's entirely it.
It just doesn't catch — I get the odd backfire when I switch the ignition off.
Attached are the MSQ and MSLs from today.
triumph2000_20171228.msq
(182.4 KiB) Downloaded 8 times
2017-12-28_11.39.34.msl
(66.5 KiB) Downloaded 8 times
2017-12-28_11.36.35.msl
(302.94 KiB) Downloaded 7 times
Triumph 2000 Mk1 — 2 litre straight 6 — MS3+MS3X, 36-1, wasted spark — Install Details
Triumph Spitfire Mk3 — clockwork
Twitter
Re: Engine won't start
Postby Matt Cramer » Thu Dec 28, 2017 7:39 am
Something's wrong with the crank sensor input. Can you get a tooth log of an attempted start?
Postby James » Thu Dec 28, 2017 7:58 am
Hi Matt,
See attached.
2017-12-28_14.54.21.csv
(47.71 KiB) Downloaded 5 times
2017-12-28_14.53.38.csv
(27.75 KiB) Downloaded 4 times
Twitter
Postby Matt Cramer » Thu Dec 28, 2017 9:03 am
It's missing a lot more teeth than the missing teeth. Try a tighter sensor gap, or adjusting the VR trim pots.
Postby James » Sun Jan 14, 2018 4:01 am
HI Matt,
For sure something was up with the sensor and the connector. The crimps on the connector weren't so good, and the plastic on the sensor had gone soft over time so was a bit wobbly. (read — bad crank sensor mount design) So I replaced those, hoping it would be the issue.
Looking at TunerStudio whilst it's cranking it's still not syncing right.
The tooth logger on screen looked much better — but still no starting. I've attached the logs.
2018-01-14_10.49.48.msl
(576.26 KiB) Downloaded 3 times
2018-01-14_10.51.42.csv
(23.54 KiB) Downloaded 5 times
2018-01-14_10.51.37.csv
(33.17 KiB) Downloaded 4 times
Twitter
Postby James » Mon Jan 15, 2018 5:23 am
Looking at the logs — could it be that the voltage is dropping off and causing the sync error 2?
It goes down to 7V or so.
The battery turns over the engine reasonably ok — but all this attempting to start has had a bit of a toll.
Twitter
Postby Matt Cramer » Mon Jan 15, 2018 8:02 am
There's still a few points where it fails to read a real tooth. More cranking voltage would boost cranking speed, and if this is a VR sensor, more cranking speed gives a stronger signal.
Postby billr » Mon Jan 15, 2018 9:53 am
I gotta admit: I didn't look at the MSL last night, only the CSVs. Your cranking rpm is only about 130, not what I would call "reasonable". Get a good battery in there before looking for other problems. Were you activating the throttle wildly during some of those crankings, or is that TP action logged a separate symptom?
billr
Postby James » Tue Jan 16, 2018 10:38 am
Matt Cramer wrote:There's still a few points where it fails to read a real tooth. More cranking voltage would boost cranking speed, and if this is a VR sensor, more cranking speed gives a stronger signal.
Yep it's a VR sensor. I'll connect up a jump battery to give it some more juice.
Twitter
Postby James » Tue Jan 16, 2018 10:40 am
billr wrote:I gotta admit: I didn't look at the MSL last night, only the CSVs. Your cranking rpm is only about 130, not what I would call "reasonable". Get a good battery in there before looking for other problems. Were you activating the throttle wildly during some of those crankings, or is that TP action logged a separate symptom?
I'll sort the battery and try again. I did have my foot on the throttle — no idea why! Out of frustration probably :)
Twitter
Return to MS3 General Support
Users browsing this forum: No registered users and 4 guests
