Help figuring out ckp and cmp wires
Postby Shogun » Thu Dec 28, 2017 12:03 pm
Hello , im in the middle of installing a new ms3 pro evo. New to the device , not new to wiring. On a taurus sho 89-95. Both sensors are hall effect , and both have 4 wires. The B+ one is obvious , im stuggling on which wire to drop , and of the remaining two , where they go. Ive provided the correct EVTM manual pic. https://ibb.co/iAnRHG
Shogun
Re: Help figuring out ckp and cmp wires
Postby billr » Thu Dec 28, 2017 1:17 pm
If you are trying to figure out the pin-out of the sensor, we need data about that particular sensor, not how to connect sensors to the MS. Also, the picture format is one I can't zoom-in on, it would be of limited use even if it did have the needed info.
billr
Postby Shogun » Fri Dec 29, 2017 3:48 pm
What kind of infos you need from those sensor ? Part numbers? Pictures? Im not sure what you need. Thanks!
Shogun
Postby Shogun » Tue Jan 02, 2018 7:26 am
Hello?
Shogun
Postby billr » Tue Jan 02, 2018 6:09 pm
Anything you have on the sensors may help. At minimum, the manufacturer and P/N of ones you have on hand, and the OEM application for the type. On the "OEM application", I mean full make/model/year/engine.
billr
Return to MS3 General Support
Users browsing this forum: Bing [Bot] and 3 guests
