no map sensor data
hemicuda
no map sensor data
Post by hemicuda »
Cuda tune.msq
(261.7 KiB) Downloaded 30 times
Cuda 3.msl
(278.32 KiB) Downloaded 19 times
Cuda 3.msl
Finished new installation of the gold Box with harness on my 2004 5.7 Hemi. It came with a base tune and started right up, briefly. Barely runs as it's extremely rich. The map gage on the dash never moves once the engine is started. Reads about 100 all the time. Has plenty of vacuum and I tried a new sensor with no difference. Datalog shows no map data once the engine is started. I'm using Tunerstudio mS Lite v3.0.28 and MS# 1.4.1 release. I'll try to attach the datalog.
hemicuda
Re: no map sensor data
Post by hemicuda »
IF anybody else has this problem with their Gold box wiring harness just swap the 2 outside wires on the map sensor plug. Seems to have solved the problem of no sensor output. Now I can start adjusting in the tune.
