Tps Vref
Tps Vref
I'm using a V3.57/MS3X and trying to work out how many sensors can be attached to tpsvref (pin 26) in addition to the Tps. Need to use some pressure sensors for my set up.
Nissan D21 Stock D/Driver
Nissan D22 KA24DET MS3X, gtx3076, Kelford cams, 950cc injectors, LS1 coils, custom manifold & exhaust.
Re: Tps Vref
How many sensors do you need and how much current does each one draw? You can certainly draw 100mA safely and probably more if needed.
Re: Tps Vref
needed to add 2 pressure sensors, 100mA will be enough.
Thanks, Cam.
Thanks, Cam.
