I want to run fuelload up to 300kpa absolute (2bar above atmospheric pressure).
I am using the stage option, firmware version MS3 release 1.5.0.
I don`t know why he keeps saying that the maximum fuel load is 250%. I need up to 300%, considering that is the same value as my map pressure 300kpa.
What shall I do?
Maximum Fuelload
Re: Maximum Fuelload
Make sure you have set the maximum boost level under Basic Set-up -> Gauge and Settings Limits.
I checked the Gauge and Settings Limits and is OK.
The message still the same, maximum 250%.
Here is the msq file.
- Attachments
- GolPrataMS3XSEQ_2018-01-11_21.05.22.msq
- (274.89 KiB) Downloaded 28 times
That's a bit unexpected - I can enter up to 500 kPa fuel load if I open that tune, and the VE and ignition tables both top out at 350 kPa when opened.
If you can do it, that will be great....
