coil near plug
arnold1
coil near plug
Post by arnold1 »
I'm in the middle of swapping my EDIS8 to a coil near plug set up.
The manual recommends the use of capacitors on the +12V, which I probably won't use, and a 100 pF to 0.001 µF cap on the TTL trigger input wire to ground to help eliminate back-fed noise to the Megasquirt controller, which I want to use.
Hope there is someone on the forum that can help me with this option, or should I just dump the idea with the capacitors!!
I found a capacitor: KER110 – 100 pF Keramik Kondensator Kerko RM5 63V
Can someone tell me if I can use these capacitors??
http://www.megamanual.com/seq/coils.htm
1992 Corvette C4, modified 397ci engine using MS3X, CNP, 36-1 t-wheel
DaveEFI
Re: coil near plug
Post by DaveEFI »
I would fit a cap at each coil on the +12v feed. Same as EDIS does. Won't do any harm.
Any make of ceramic cap of the correct value should be OK on the TTL side.
billr
Re: coil near plug
Post by billr »
Abandon the Megamanual, use the manuals linked-to at the top of this page. The Megamanual is obsolete, has not been kept updated and may have errors that were never corrected.
arnold1
Re: coil near plug
Post by arnold1 »
DaveEFI wrote:I would fit a cap at each coil on the +12v feed. Same as EDIS does. Won't do any harm.
I was just wondering about the KER110 – 100 pF ceramic capacitor Kerko RM5 63V I mentioned because it only supports 63V.
