MS3X extra inputs
MS3X extra inputs
ive been trying to use the extra Analog and Ditgital inputs on my MS3X. when i first setup my MS3x i used a GM Temp sensor to log lower radaitor hose temp and to control my fans. After a while that channel would bounce between 0 and actual temp, so I reverted to normal fan control. Now im trying to use the extra I/O on the MS3X card to have variable boost control along with an on/off switch for traction control. The switch inputs give me nothing no matter what i try. I pulled the ECU and hooked up the jim stim with the extra analog output hooked up to pin for Lower Clt. After playing with it and logging it i could see any time the ECU sees an RPM signal the Lower ECT signal bounces around.
- Attachments
- lower clt.msl
- (214.82 KiB) Downloaded 19 times
Re: MS3X extra inputs
Can you also post up the tune file that this log was taken on?
