1JZ MS3X popping noise at idle
as title says my 1jz is popping at idle, and afr and rpms swings around at same time as the popping. but it revs fine and runs fine. MS3X running on a 2jz base map (not tune yet), 1jz with a single turbo 6262 T3, 800cc injectors, GM LS2 Coils, Quantum 340lhp fuel pump, Spec Stage 3 clutch 6 pucks, R154 gearbox, 14point7 Spartan O2 sensor, im using the MAP sensor from the squirt. the popping occurred also with the stock ecu. any help will be appreciated.
Re: 1JZ MS3X popping noise at idle
If it occurred with the stock ecu I am inclined to suspect a mechanical issue.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
I know im not burning oil or loosing coolant. what mechanically could be?
Valve clearance too tight is one that comes to mind........... Can you tell exactly where is the 'popping' is coming from? (ie. intake, exhaust......)1jzTaco wrote:I know im not burning oil or loosing coolant. what mechanically could be?
Muffler
Sent from my SM-N950U using Tapatalk
Popping usually mean misfires, check those plugs, maybe too short gaps, AFR, etc
This is likely plug gap. What are yours gapped to? Also, too MUCH timing can cause this as well.
gapped .032shaodome wrote:This is likely plug gap. What are yours gapped to? Also, too MUCH timing can cause this as well.
