Boosted 5.3 LS full factory engine sensors, pre turbine injector, boost control, boost by gear(speed), launch control, anti lag, traction control, cooling fans, knock sensors, Bluetooth, MSDROID gauges, etc
I am under the impression that I do not need to install this for LS coil packs. When running all that I have planned do I need to do something with this output to make it available for another use or will the ms3x card provide me with enough?
Ms3x q16 driver help!!!
Re: Ms3x q16 driver help!!!
It doesn't look like you need to set this pin up as an output with the features you list.
Thanks! Also one more question. It says test the TSEL for 0-5v before fitting the processors. I did that and got .01-.02v is this okay? 0-5v seems like a large range. After reading the instructions 10x I plugged in the CPU and nothing got hot and all seemed okay just double checking before I start with the ms3x board.
Just make sure it hasn't somehow gone OVER 5 volts - that can damage the CPU. 0 to 5 volts is the range of output voltages that won't damage anything.
