Which way to go
Which way to go
Hi All,
Many years ago I became interested in the Megasquirt project. I intended to build a Megasquirt for my Land Rover project which is/was a 1984 110 Land Rover V8 with an upgraded engine from the standard 3.5 to a 4.4 from a Leyland P76.
The intention was to use EDIS, 36-1 trigger wheel and multipoint injection using a "THOR" manifold from a Land Rover Discovery 2.
The project was shelved whilst I fell in love, sold my house with an awesome shed and moved all my projects to my parents farm in storage.
I have a partially assembled Megasquirt board version 3 with the Megasquirt 1 CPU.
Of late I have been thinking I should get this project finished and finish the Megasquirt so its ready to go. Is MS CPU 1 still the go or should I buy a MS CPU 2.
At the time MS Extra on the MS2 was not available and MS Extra on the first CPU was the only choice. Is it still advisable to use the EDIS module to control ignition?
Cheers
Richard
Cheers
Richard
Re: Which way to go
If you already have an EDIS 8 module, I'd probably stick with it. Makes for a simpler installation. Do you have the Thor coils?
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
Re: Which way to go
Hi DaveEFI,
I have a set of new EDIS Ford Coils and leads. I don't have EDIS8 module. I also have a set of Secondhand Thor coils.
Re: Which way to go
EDIS (and Thor) coils are passive units, so need high current drivers. The EDIS module supplies these - or you can use an add on high current driver module with MS2 (the V3 board has only provision for 1 high current driver as standard). Probably also with MS I. MS2 includes a stepper motor driver which I think is needed for the Thor manifold, for idle control. I'd personally buy the MS2 daughter board, as MS1 is a bit obsolescent these days. Or you might consider an MS3 as it has more options.dickyjoe wrote:Hi DaveEFI,
However, if you want to keep things simple, an MS2 with EDIS module will work very well on the RV8. That's what I'm using.
You will need a wideband O2 system though. Tuning without one is very difficult.
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
Re: Which way to go
Without the EDIS module, you can (if you like soldering!?) add the necessary ignition drivers into the Megasquirt and control the coils directly.
For a wideband, I'd consider TechEdge as they are based in Australia.
Re: Which way to go
I suppose it will also depend on how much a EDIS8 module with pigtail will cost in Oz?
Rover SD1 3.5 EFI
MS2 V3
Tech Edge O2
London UK.
MS2 V3
Tech Edge O2
London UK.
Re: Which way to go
Thats very true.
I have seen them second hand on ebay in the states. Is that the way to go? Or through a supplier?
