Assembled my MS2-V3.0 board today. Everything went smoothly apart from putting in the SP232 UART chip in backwards. Rather than risk damaging the board by sucking it out I decided to cut the pins off. Now I need another UART.
The one that came with the (DIYAutoTune) kit was an SP232. Can I replace this with a MAX232 which are cheaply available at my local supplier? Does it matter what variant? I have a CPE+, NG4, N and IN variant to choose from.
Cheers!
Can I replace SP232AEP with MAX232?
Previous Megasquirted car: Volvo 940 Turbo
Current project: MX-5 mk2 1.8, MS2/PCBv3.0, [future] custom made manifold, turbo
Re: Can I replace SP232AEP with MAX232?
We cross shop a couple of brands to get the best deal on parts for our kits; the main difference is the SP232AEP is made by Exar and the MAX232 by Maxim or Texas Instruments. The variations you mention decode to:
CPE+ = Maxim, 0 to 70 degrees C
NG4 = TI, 0 to 70 degrees C
N = TI, -40 to 85 degrees C - this is the one you want.
IN = TI, 0 to 70 degrees C
Thanks Matt.
Looking at the datasheet it appears the MAX232N requires 1.0uF charge pump caps instead of 0.1uF ones, and it looks like the ones in the schematic are 0.1uF. I take it I should replace these as well?
Cheers.
Cheers.
The MAX232A variants can use 0.1 uF's.
Found a MAX232ACPE+. Rated -40 to +85C. That should do it, I think. Cheers for the help
I've used MAX232's with .1uF caps without issue for a few different applications (not MS related), but the functionality is the same.
Tha Daily: 2005 Chevy Blazer
Thanks all. I've been able to load the firmware onto the board and can connect to it with Tunerstudio, so I guess it's working
