pt4 circuit
pt4 circuit
hi guys do anyone know if there its a throw hole part # for the bat54swt1g need it to replicated the pt4 circuit.thanks
Re: pt4 circuit
Two BAT42 or BAT43 in series would have pretty close characteristics to the BAT54, but for the service in question, you could probably use a pair of any small Schottky diode.
Re: pt4 circuit
ok im going to built the circuit that its on the manual section 3.4.10 to use a hall sensor for vss2 that should work on js11.
Re: pt4 circuit
Ok I built the circuit and I'm getting wacky reading in vss2 when the sensor touch the wheel stud I get 0 mph but as soon the sensor move away from the stud I get wacky reading 200 and up mph what could cause this.thanks
Re: pt4 circuit
Nobody should I built the 12v input circuit
Re: pt4 circuit
ok i did a test with a led light and the light stay on all the time even with the sensor hanging on the air, i check my wiring and everything its fine i believe that i have a bad sensor when i press the end of the sensor where the wires goes the led go off and the vss2 gauge go to 0 as soon i let go the wires i get the wacky reading.so time to order a new sensor.
