U3 6pin chip orientation
lukej
Post by lukej »
Hi I need a bit of help with the orienation of U3, theres no notch on the chip to correspond with the notch on the board,
MS2
V3.0PCB
any body got any advice?
much appreciated :)
Re: U3 6pin chip orientation
Post by jsmcortina »
Is there a dot? That indicates pin 1.
Also if you look at the chip with the writing the correct way up, pin 1 should be bottom left.
lukej
Post by lukej »
ok so the dot goes the same end as the notch or the dot goes the opposite end?
got another major issue....
let me sort U3 out first though!!!
lukej
Post by lukej »
jsmcortina wrote:Is there a dot? That indicates pin 1.
thankyou James, ive found clarification on the pcb layout http://www.msextra.com/doc/ms2extra/MS2 ... htm#layout
onto other issues... ive gone and soldered U4 where U7 should go :oops: :| :| :|
taking it real slow steady with the heat trying to use the solder sucker on it
kjones6039
Post by kjones6039 »
lukej wrote:onto other issues... ive gone and soldered U4 where U7 should go :oops: :| :| :|
Another good reason to install sockets, IMHO.
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
lukej
Post by lukej »
yeah maybe... hindsight and all that :(
