Page 1 of 1
multiple coil direct fire
Posted: Fri Feb 24, 2012 9:17 am
by lukej
MSII v3 pcb.
can someone just clear a couple of things up for me please. i'm following these instructions http://www.diyautotune.com/tech_article ... squirt.htm for multiple coils as i'm direct firing a ford edis coil using 2 BIP373's (no edis)
as it stands, ive finished the main board assembly and now i want to install my ignition, first off, where do i mount the 373's? do i just screw them to the case? and secondly, is it as simple as (regardless of mounting location) soldering:
left leg to a 330ohm resistor going to (1) top of r26 and (2) top of r29.
middle leg to (1) IGN and (2) IAC2B.
right leg to DB37 ground pins.
Thanks for your help
Re: multiple coil direct fire
Posted: Fri Feb 24, 2012 10:21 am
by SymTech Laboratories
lukej wrote:first off, where do i mount the 373's? do i just screw them to the case?
You can mount them directly on the case. Often, one can omit the injector driver current limiting circuit, which means you can install a second BIP373 where R37 or R38 would go on the heat sink bar. There's already a spot for the first BIP373 labeled "Q16". Wherever you mount them, be sure to use mica insulators.
lukej wrote: and secondly, is it as simple as (regardless of mounting location) soldering:
It's basically as simple as that. If you mount the first BIP373 as Q16, then you can just use a piece of jumper wire between IgbtOut and IGN. The wire with the 330 ohm resistor goes to IgbtIn, and R43 should either be installed or jumpered (do not leave it omitted).
There's some more information, as well as a diagram, on the subject here:
http://www.msextra.com/doc/ms2extra/MS2 ... htm#2coils
Posted: Fri Feb 24, 2012 11:05 am
by lukej
thankyou for your time :)
is IGBTIN the left leg of the 373 at Q16 then i take it.
Posted: Fri Feb 24, 2012 11:11 am
lukej wrote:is IGBTIN the left leg of the 373 at Q16 then i take it.
That's correct.
Posted: Tue Sep 04, 2012 8:50 am
by kupa
That's correct.
Thanks for this reply :yeah!:
