I have a problem whith Sync only when start!
Whenn I start the engine when is cold I have Lost Sync Reason 2 and Half Sync not Full Sync !
I have the problem only when start, when the engine run all is good!
I've tried:
VR Sensor gap small (0.15mm) = is better no good
VR Sensor wire shielded = is no better
second battery = is better not always
What can I make?
My Hardware:
Cam VR Sensor on MS3/X
Crank VR sensor on V3.0
Engine Yamaha FJ1200
Crank VR Sensor Stock Trigger Wheel 24-1 Home made
Cam VR Sensor Honda CBR600 (signal good!)
in the log you can see the start bei 361.xxxS I have Lost Sync Reason 2 and Half Sync, the start bei 365.xxxS is good and Full Sync!
frank
Lost Sync/Half Sync when cold
Re: Lost Sync/Half Sync when cold
and the next problem
when the engine hot and i start no Full Sync!
5x start = 4x Half Sync and 1x Full Sync!
in the .csv log (Half Sync) is no Lost Sync Reason? frank
Hi Frank, did you give a solution to your problem? I have something similar. When starting the engine starts in half sync many times and it doesnt recover to full syn unles I restart and starts in full sync.
Hi Josu
Now I have a 24-2 wheel (befor 24-1) and my Skip Puls by 11.
By 10 cold start's I have 1 Half Sync.
Frank
I can not remember exactly?Josu wrote:Hi Frank, did you give a solution to your problem? I have something similar. When starting the engine starts in half sync many times and it doesnt recover to full syn unles I restart and starts in full sync.
Frank
