Fuel pump circuit
Re: Fuel pump circuit
If you desolder R19, does the PMP light go off?
Here are some pics. I will take out R19 and see what happens
I removed one side of R19 and PMP is still lit up. Whats next?
Sounds like you have a short-circuit on the transistors.
Q14, Q15, Q20 are showing continuity between 2 legs. All other transistors test ok.
The "continuity" (actually an ohm or less) is normal. What about Q2? A short between pins 1 and 3 would cause the symptom you're describing.ur2slo wrote:Q14, Q15, Q20 are showing continuity between 2 legs. All other transistors test ok.
Okay, Im getting 5V coming into R16 when injectors are firing from stim. What should I be getting at FP1? What are the specs of D4?Matt Cramer wrote:Ok, here's the relevant schematic:
First, put it on the Stim and check if there's 5 volts coming into R16 (that's the turn on signal).
Q2 is switching the connection to ground, so you won't measure any voltage at FP1. D4 is 22V/1W Zener diode. It shouldn't be damaged, but if it is, the fuel pump will remain on indefinitely.ur2slo wrote:Okay, Im getting 5V coming into R16 when injectors are firing from stim. What should I be getting at FP1? What are the specs of D4?
Im getting 5V at FP1
With the fuel pump relay connected?ur2slo wrote:Im getting 5V at FP1
No, that is just with the stim connected.
Could you repeat this test, but with R16? R19 is for the FIDLE circuit, not the fuel pump relay circuit.ur2slo wrote:I removed one side of R19 and PMP is still lit up. Whats next?
Hello guys,
I have the same problem with my fuel pump circuit. I measured the voltage at R16 which is 4.85 volt on both sides. I checked R40 which is 1 ohm.
I have no sim and ECU is in a running car. Problem is that for now fuel pump is always on when car is on ignition and i would love to fix it.
Any more checks i can do?
I believe the original poster's issue was that his FP wouldn't turn ON; you say yours won't turn OFF. From one of the posts above:Red_bull wrote:I have the same problem with my fuel pump circuit.
Remove your D4. If that solves the problem, you need a new one. If it doesn't, check your wiring; make sure the pump is fed from the relay OUT pins, not the IN pin(s).SymTech Laboratories wrote:D4 is 22V/1W Zener diode. It shouldn't be damaged, but if it is, the fuel pump will remain on indefinitely.
Remove the daughter card and check again. If the pump still runs continually, likely a problem in the wiring or driver circuit. If not, a problem with software or the daughter card.Red_bull wrote:Hello guys,
Ok now i see my post was a bit messy (sorry i was mega hangover yesterday)
- Pin 37 does not go to ground, but has 5 volt on it when the engine is running (like the first post of the original topic)
- Pin 37 stays as zero when i put ignition on and only comes up when engine is started. No short periode of voltage
- Currently i have the relay switched on ignition and not connected to the megasquirt
Thanks for the reply guys. Do the tips stay the same?
Yes; do Dave's check first.
But i get the 5 volt when the engine runs. So if i remove the daughterboard i won't be able to start the car.
Is removing D4 the way to go?
Pull the daughtercard; do you still have the same malfunction?
THEN pull D4.
THEN pull D4.
