Fuel pump circuit
Fuel pump circuit
Ive never gotten my fuel circuit to work. Im not sure if I fried something or didnt assemble something right. The car runs fine otherwise.
Shouldnt megasquirt be putting out a ground signal on the fuel pump wire? Im not getting it, Maybe 5 volts positive
What did I do wrong?
ITs a 93 Plymouth Duster 3L turbo
Re: Fuel pump circuit
Yes, it should put out a ground signal. Does it work OK on a Stim?
First time I plugged the stim in since I built it. Now I'm not getting rpm readings out of it. Works in the car. The PMP led is lit up.
Does the PMP LED stay on (if it is, something's shorted) or turn off after 2 seconds of not seeing RPM (which it should)?
No it stayed on, unfortunately.
Is it fixable?
Thanks for your help
Is it fixable?
It can probably be fixed. What main board do you have?
MS2 V3.0
Ok, here's the relevant schematic:
First, put it on the Stim and check if there's 5 volts coming into R16 (that's the turn on signal).
I'll check that when I get home tonight. Can you tell me the next step to check if I do or don't have the 5v at R16?
We would reload the firmware next. If that doesn't change anything, you may need a new processor.ur2slo wrote:I'll check that when I get home tonight. Can you tell me the next step to check if I do or don't have the 5v at R16?
I'm getting 2.4v
On both sides of R19? Is Q19 shorted anywhere? Is Q19 inserted the right way? Is R40 the correct value (1 ohm)?ur2slo wrote:I'm getting 2.4v
Ok. With fresh batteries in the stim and meter I'm getting 1.822v going in and 64.1mv coming out of R16.
R40 is 1.4 ohm
R40 is 1.4 ohm
You might try replacing R40 with a 1 ohm resistor. With a 1.4 ohm resistor, the current will be limited to just ~500mA.ur2slo wrote:R40 is 1.4 ohm
It's the right resistor in there, could I be getting that reading because it's in the board?
Can I get a link to the proper firmware?
Downloaded new firmware, same problem
PMP stays on and no rpms from stim
Any ideas, I'd like this setup to work like it was meant to
You can measure voltage in-system, but not resistance.ur2slo wrote:It's the right resistor in there, could I be getting that reading because it's in the board?
You might try posting a few clear pictures of the top and underside of your MegaSquirt board for us to spot any obvious problems.
