Low voltage indicator?
Was wondering if there is already code to add to the .ini to turn an LED on when voltage is too low. I plan on running a typical generator light tied through the alternator but thought it would be better to have a programmable output for a light when it is below a certain voltage.
Im planning on running the newest MS2 stable firmware which looks to be 3.2.4
Re: Low voltage indicator?
You can configure an LED as a programmable output, then select "batteryVoltage" as the output channel. You shouldn't have to modify the .INI file.
The LEDs are used up by spark outputs. Ill see what other outputs I have available and how I can program them.
We only said to use an LED because you mentioned them, but you can use any free programmable output.MattyB wrote:The LEDs are used up by spark outputs. Ill see what other outputs I have available and how I can program them.
I meant an LED as a dash board indicator, mia culpa
Since I have this thread here, is there a way to flash the OUTPUT (not LED as that is misleading) when it is below the programmed threshold?
Im used to playing with the older MS stuff so forgive me , my username went bye bye a long time ago and I tend to lurk when I need to figure something out. I usually do a lot of DIYPNP stuff that doesnt require a lot of modification so consider me old school catching up with the new school.
We apologize for the confusion; if you meant an indicator this whole time, then you will have to add a line or two to the custom.ini file to add a custom "OutputChannel". We don't currently know of any way to make an indicator flash.MattyB wrote:I meant an LED as a dash board indicator, mia culpa
- Running MSx/Extra
Matty
I had a problem burning cue to low voltage,this cured it...
http://www.ebay.co.uk/itm/390567117059? ... 1439.l2649
John
John
Simple, use a generic output and have it come on when Vbatt < your threshold.
Use a 12V flashing LED, positive lead to ignition, the other one to the output.
Thanks for the input guys. Figure if I cant set an output to blink in code (probably can but I don't know how), then I can add on a PIC 12F683 powered from the 5v proto output and then program that to do what I want based on a simple digital on/off signal from a free output from the MS.
This shouldnt be necessary as Im quite confident that the MS mcu is more than capable of outputing the necessary signal to blink an external indicator, but if nobody knows what code would need to be written to do this I'll just use a micro that I can do it with.
You can use the existing spare output ports setting to turn on (but not flash on and off) an output when the battery voltage is too low. It sounds like you may want something more complex, though - but if you can program a PIC, you could probably also change the MegaSquirt firmware.
A blink routine for a pic is seriously easy, especially with a BASIC compiler. Id try it in the ini but since I only know how to write in BASIC, Im not gonna risk corrupting anything if I screw it up.Matt Cramer wrote:You can use the existing spare output ports setting to turn on (but not flash on and off) an output when the battery voltage is too low. It sounds like you may want something more complex, though - but if you can program a PIC, you could probably also change the MegaSquirt firmware.
I wouldn't mind knowing the ins and outs of the code as it would make a lot of mods (like this one) a lot easier to do.
If it was a simple as something like this
Code: Select all
Main
If vBatt <12.0 then flash
goto Main
Flash
pin5=high
wait 1000
pin5=low
goto Main
have you been here... http://www.msextra.com/forums/viewtopic ... 91&t=43601
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
No I haven't, I'll take a look and see what I can't learn. Thanks for the link.nismoautoxr wrote:have you been here... http://www.msextra.com/forums/viewtopic ... 91&t=43601
