Hi @ all
I just finished building my MS3x for my '99 Miata using a great wirteup from a member of miataturbo.net
As with MS3x, many components of the V3 Mainboard are not needed, my board looks like this:
The only output I'm using on the Mainboard is Fuel Pump.
But now I wanted to add Fidle as generic output, mainly just to try it out but also to have an additional output over those from the MS3x in case I need one in the future.
I read through the assembly guide at msextra.com which told me to solder in further 4 parts. Q4, Q20, R39, D8
I did that but when I set Fidle as generic output, the Fidle LED on the JimStim still is not lighting up.
I attached my current.msq, using TunerStudio v2.5.05 with MS3 Release 1.3.0
Can somebody please tell me what I did wrong? Did I miss some more parts to solder in to make this work?
Thanks, David
Fidle generic output not working (MS3x+JimStim)
Hi @ all
I just finished building my MS3x for my '99 Miata using a great wirteup from "WestfieldMX5"
I read through the assembly guide at msextra.com which told me to solder in 4 further parts. Q4, Q20, R39, D8
Thanks, David
Thanks, David
Re: Fidle generic output not working (MS3x+JimStim)
Forgot R19.
Graduate of EFI University.
Yiehaa, it works!!
Thanks a lot!
A different question: Is there any possibility to have an analogue 0-5V output?
I would like to output the MAP Signal from the internal MPX 4250 to an external MAP Gauge wich is pre-set to its own 0-5V Sensor, which is why i need to make some kind of conversion.
Thanks a lot!
Hi David
I missed R19
Frank
Look here http://www.msextra.com/doc/general/ms3v3schems.html (Output other)David_G wrote: I read through the assembly guide at msextra.com which told me to solder in further 4 parts. Q4, Q20, R39, D8
I missed R19
Frank
Ah thats where R19 comes from, nice!
Next time I will have a look at those schematics first
Thanks again!
Thanks again!
