Option for RS232/DB9 to USB? Will it work?
Looking at the FTDI products page I came across this
http://apple.clickandbuild.com/cnb/shop ... goryID=100
Question is, would it work? I know typically using a length of USB cable can potentially cause serial communication errors in some applications. Reason I am asking is because I am plagued by serial communications issues because my laptop does not have a serial port, so I am using the DIYAutotune serial to USB converter with the usb extension cable. I get typical RPM spikes and some insane numbers for values, however the engine does not skip a beat and resets are almost nil at this point.
Its not grounds, they are all done per the article that is so ruthlessly pushed here, lol. Also completely rewired the entire harness using the DIY Megasquirt harness. Megasquirt info for this build is in my sig.
I have resorted to using the serial cable with the serial to usb adapter at the very end to eliminate the USB cable, but have been unable to test it out due to having an expired license, which I should have renewed by the beginning of next month.
Looking to see if the above product would work or would using the USB cable again cause issues?
Megasquirt 2 V3.0 Running Msextra 3.4.2. in a 1989 Camaro RS .48AR/60mm Turbo 3.4L/700R4
Boost control, Fan control, Stepper IAC, Launch/Antilag, Working on the GMDIS, and Methanol injection
Re: Option for RS232/DB9 to USB? Will it work?
From a quick read, I would think it would work.....
Just one old guys opinion though! Curious though.... What's the raccoon's take on this?
FWIW............ That is the setup I prefer and would be my preference. I have had some difficulty with long USB cables in the past. The shorter the USB (if you can't use straight serial), the better, IMO.WillExoIX wrote:I have resorted to using the serial cable with the serial to usb adapter at the very end to eliminate the USB cable
MS2 v3 w/extra 3.4.2 Release
TinyIOX from JBPerformance
Talk about getting ripped off, he wants 3 bins just for his opinion!kjones6039 wrote:From a quick read, I would think it would work.....
What laptop are you using,
I am using a IBM Think pad T41, no serial port built in.
Purchased a docking station that has a serial port. Works good.
Or a Card Buss to RS232 serial adapter
I'm confused. What would be the advantage over using a suitable length serial cable with the serial to USB adaptor at the laptop end?
Dell inspiron b130Ollie8974 wrote:What laptop are you using,
Just wondering if its a viable option, though it would still use a usb cable which is what causes the primary issue anyway. So I guess it would be a moot option.DaveEFI wrote:I'm confused. What would be the advantage over using a suitable length serial cable with the serial to USB adaptor at the laptop end?
Did you install the FTDI driver here,
Scroll down to 3A.
http://www.msextra.com/doc/ms3/serial_setup.html
Have you considered a docking station,
This photo of a Dell docking station shows a serial port.
Scroll down to 3A.
I'd say it is a long USB cable which is more likely to be the problem. Serial is pretty robust. So use a short serial to USB adaptor and make up the required length with serial. That works just fine here.
My laptop doesn't have a docking port. Im using a FTDI chipset serial to USB with the applicable driver installed. Its the USB cable as far as I can tell. Using the serial cable with the serial to USB converter and haven't had any issues yet. Also switched to tunerstudio from megatune.Ollie8974 wrote:Did you install the FTDI driver here,
Scroll down to 3A.
Yes this seems to work much better. Have the serial cable with the adapter on the end and haven't had a problem yet. Taking a datalog tomorrow so I will know for sure.DaveEFI wrote:I'd say it is a long USB cable which is more likely to be the problem. Serial is pretty robust. So use a short serial to USB adaptor and make up the required length with serial. That works just fine here.
