Extra Spark
Extra Spark
I"m not sure if i have my board wire correctly. It's an ms2 w/v3.0 board going to run it on a ls1 with batch fuel an wasted spark. install a extra db15 connector cause wasn't sure nor confident pinning it to the 36. Using 4-BIP373 4-330 resistors
Top of R26= Spark A
Top of R29= Spark B
Top of R27= Spark C
JS11 = Spark D
Top of R26= Spark A
Top of R29= Spark B
Top of R27= Spark C
JS11 = Spark D
Re: Extra Spark
What coils are you using? LS1 coils do not require BIP373 as they have built-in ignitors. You need to build logic level spark outputs for LS1 coils.
See section 5.3 in the hardware manual.
Re: Extra Spark
Yes running ls coils. will this setup not work? Can you send me the manualjsmcortina wrote:What coils are you using? LS1 coils do not require BIP373 as they have built-in ignitors. You need to build logic level spark outputs for LS1 coils.
Re: Extra Spark
I'm afraid not.parkeyl wrote:Yes running ls coils. will this setup not work?
Click on the Manuals link above.Can you send me the manual
Re: Extra Spark
I have the manual was making sure it was the same that i have been reading. So im needing to run the TC4427. Correctjsmcortina wrote:I'm afraid not.parkeyl wrote:Yes running ls coils. will this setup not work?Click on the Manuals link above.Can you send me the manual
Re: Extra Spark
That would be the best option but you can do it with the resistor method 5.3.0.4 section on the manual.parkeyl wrote:I have the manual was making sure it was the same that i have been reading. So im needing to run the TC4427. Correctjsmcortina wrote:I'm afraid not.parkeyl wrote:Yes running ls coils. will this setup not work?Click on the Manuals link above.Can you send me the manual
Re: Extra Spark
[/quote]
Using 2 TC4427s is the preferred method as it keeps the spark output going high which is safer than going low.
[/quote]
Support the developers!
