Im about to install an oil temp sensor (GM) and plan to use EGO2 . Reading up on generic sensor inputs page in the manual it says to intall the bias resistor either in harness or on the ms3x card on r65,r66, or r67. Which one is for EGO2?
EDIT: nevermind ...I see where it says R65,R66,and R67 are for ext_map,ego2, and spare_adc RESPECTIVELY...so I guess that means R66 is where my 2.49k bias resistor would go.
adding an oil temp sensor input question
Ricky-
MS3&MS3X v.3.0 PCB
LS3/LSA card MAF sensor
97 Mazda MX5
MS3 2002 vvt motor
.60 trim T4 Turbo at 15 PSI
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
Re: adding an oil temp sensor input question
yes R66 is for EGO2
thanks for the confirmation.
Ricky-
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
MS3&MS3X v.3.0 PCB
97 Mazda MX5
MS3 2002 vvt motor
