MS 3 assembly help
MS 3 assembly help
I've got a MS3(MOD EDIT) V3 with a 3X board that was built to run a 36-1 wheel, crank sensor and hall effect distributer. These would drive sequential 4cyl with Toyota Coil-on-plugs. I plan on running a 4G63 sensor instead of the 36-1 wheel. I get lost when I look at the MSExtra section on how to setup for 4G63 sensor. Here is where I am, is there anyone that can help?
Ok, step one in msextra to add a cam sensor input..." The OptoIn pad should be connected to a spare pin on the main DB37 connector (e.g. SPR3)"
I can't seem to find OptoIn, and SPR3 doesn't look like a spare pin on DB37.
Step 2, "Connect OptoOut pad to JS10", I can't see OptoOut but see that JS10 pin will connect to the 3X card
Step 3, "Jumper XG1 - XG2" , can't seem to find that at all.
Step 4, " Check that R12 is a 390R to 470R resistor, replace if not" Found the resistor in place, gotta check the resistance.
Step 5, "Install 470R resistor on the Proto area to 5v+"
Step 6, "Jumper the other end of the 470R resistor to OptoIn", I can't find OptoIn
Step 7, " Ensure that C30 is not fitted", C30 has something there, and I'm not sure what its for.
Re: MS 2 assembly help
I'm confused, 3X board?
Flip the V3.0 board over, the opto things you're looking for are silkscreened on the backside. SPR3 is pin 5 in the db37.
Pictures of what you've got would help me.
Graduate of EFI University.
Aside from the MS2 vs. MS3X confusion, it sounds like you are reading some old documentation perhaps?
The new documents do not use the opto-isolator for 4G63.
http://i63.photobucket.com/albums/h155/ ... f56c5f.jpg
http://i63.photobucket.com/albums/h155/ ... d846cf.jpg
http://i63.photobucket.com/albums/h155/ ... 76a9fb.jpg
http://i63.photobucket.com/albums/h155/ ... 80860e.jpg
The board looks like a MS3 with the large busbar on the side and has V3.0 written on it with what looks like the MS3X daughtercard. The writeup I found for the DSM CAS is on http://www.msextra.com/doc/pdf/MS2V30_H ... de-3.3.pdf ...which now that I see it means I was looking at the wrong one.
That's an MS3 on a V3.0 mainboard. I don't see an MS3X there.
The manual you want is : http://www.msextra.com/doc/pdf/MS3baseV ... re-1.3.pdf
Ok, I'm slowly coming around. Is the white card the MS3 daughterboard? Right now there is nothing running to the add-on card. Would picking up the MS3X card make it a plug and play deal for the other cam input?
Man, $105 for a second cam input. Well, maybe I can take advantage of the other parts of the MS3X card. Off to spend more money...
Thanks guys
Thanks guys
Have you read the MS3base manual PDF? It tells you how to add a cam input without the MS3X card.
