No VCC when MS3 daughterboard installed
pit_celica
Post by pit_celica »
I was testing a fully assembled v3.57+MS3+MS3X board on my bench today and I think I fried something. I was trying to adjust the VR pots using a press drill and a distributor. While adjusting the R52 VR pot, I accidentally dropped my metallic screwdriver in the SD card/U3/U4 area of the MS3 when everything was still powered on. Right after, I wasn't able to communicate with the laptop anymore.
After some basic power/ground testing, I found that the 5V at VCC was going from 5V to 0.5V really fast after a power ON with the external power supply. The output of U5 is a clean 5V, but VCC is 0.5V in steady state.
I then removed the expansion board and the MS3 daughter board and the VCC is now back at 5V. As soon as I reinstall the MS3 daughter board, the VCC drops at 0.5V.
I'm pretty sure I screwed up something, I just want to make sure what it is before ordering some costly parts.
Let me know if you have any ideas.
Thanks!
Sam
billr
Re: No VCC when MS3 daughterboard installed
Post by billr »
Have you peeked into that SD card socket, made sure there aren't just some contacts that got bent and are shorting?
pit_celica
Some new info on this :
- On the main board, without the MS3 daugtherboard connected, I have 12V at pin#3 of U5 (should be 5V isn't it??). So, I also have 5V at pin #20 of the 40 pins daughterboard connector and also at the pin #26 of the DB37 connector of the main board. I suppose that U5 is bad. What other components might be faulty?
- With the MS3 daughterboard unconnected and sitting as is on it's own, there is continuity between pin #31 and pin #32 of the 34pins JP2. This means that there is a short between 5V and GND on the MS3 daugtherboard itself.
Now, what to do with this? I'm ready to send it to someone to have it diagnosed/repaired. Who should I contact in Quebec, Canada?
Thanks in advance!
Sam
pit_celica
Again, some update.
Please ignore the first point in my last post above. My ground lead from my power supply wasn't correctly connected and this lead to +12V on both left and right pins of U5. With the ground correctly connected, I now have 5V on all required places. I swapped the MS3 daughtercard with a known to be working one and all is fine now.
So, I have a MS3 daugthercard that is faulty because it has continuity between +5V and ground on itself. How do I deal with this. Please let me know what you think.
Have a good day!
Sam
If the daughter card is less than a year old, contact the vendor you bought it from directly; they're covered by a one year warranty.
For out of warranty daughter cards, Peter Florance is probably the best one to call.
