Trigger wheel/EDIS wiring to relay board MS3X
Re: Trigger wheel/EDIS wiring to relay board MS3X
Post by jsmcortina »
dragbug wrote:I suggested that back in November in the MS3 New Documentation Discussion and was ignored. Glad to see you have had a change of heart. I know it isn't something you recommend but that doesn't mean it isn't being used for simplicity sake. It can/does cause additional confusion when you want to run an MS3x card though.
Nobody else has suggested it, so it has hardly seemed like any kind of priority. Certainly no vendors have mentioned it.
craigibc
Post by craigibc »
I am using preview on the mac and search is not working. I might need to find another pdf viewer since I have no search working at all on this manual.
PIP goes to TACH on the relay board
SAW goes to PIN 14 SPK A on the DB37
Sounds right?
Craig
craigibc wrote: PIP goes to TACH on the relay board
Sounds right?
Yes
That sounds weird. Every PDF viewer I've used has search - Acrobat, evince and even the one built into TunerStudio. I searched online and saw screenshots of users searching in 'Preview' but I don't have a Mac, so can't report first hand.
muythaibxr
Post by muythaibxr »
I use a mac as my primary firmware dev machine. With the preview that's included in 10.10, I have no trouble searching. I just use command F, and type in what I want to search for.
craigibc
Post by craigibc »
interesting I can use the search as well the result finds nothing. I am using Yosemite on my Mac.
craigibc
Post by craigibc »
So to continue the clarification of some of the previous things I have setup see the statement below:
"It is important to be aware that while Ford EDIS and GM DIS both have special toothed wheels, the
module handles all the decoding and presents a signal to the Megasquirt that looks like a distributor
input. With these two modules, the Megasquirt does not know or care how many teeth are actually on the
wheel, so do not use the "toothed wheel" setting. This also means that normally you cannot use
sequential fuel with these systems as no engine position information is available to the Megasquirt."
So if I have a CAM INPUT and EDIS with sequential injection will this work correctly or should I remove the sequential injection?
Thoughts?
Craig
craigibc
Post by craigibc »
I have the toothed wheel with the CAM sensor, EDIS and sequential injection.
DaveEFI
Post by DaveEFI »
craigibc wrote:I have the toothed wheel with the CAM sensor, EDIS and sequential injection.
I don't see how that can work since EDIS only sends a tach signal to MS - ie no crank position information.
Post by Matt Cramer »
It is treated much like a dual sync distributor, using the cam signal to tell which PIP pulse is which.
DaveEFI
Post by DaveEFI »
Ah - right. Is there any advantage with this? I'd have thought it better to have a spot on timing signal from a crank trigger wheel?
I'm asking because I may well go sequential injection later this year.
craigibc
Post by craigibc »
now there is some good news!
Thanks!!!
Come on... it's covered in the manual!
http://www.msextra.com/doc/pdf/html/MS3 ... 3-119.html
6.7.6 Optional cam sensor
Megasquirt-3 supports a cam sensor with EDIS for sequential fuel. A single tooth at cam speed is required, this
should pass the sensor before the engine reaches TDC #1 compression.
craigibc
Post by craigibc »
New topic.
craigibc wrote:Any advice on why I might not fire on the injectors?
:msq:
