Ok, I have my MS2 V 3.0 built to where I need to figure out how to run the ignition. I am getting confused on how to set it up to use the stock toyota VAST set up on a 16v 4age.
Through reading and searching the forum I have found it vary between use the EDIS set up or set it up as hall/opto sensor input. So I am bringing my question here before I try soldering it up.
Second question is would it be simpler to change and use 4 logic COP set up for semi sequential.
Currently board does not even have the BIP373 installed, so it is wide open for the ignition input and output.
VAST confusion and options
