Hello,
The ms3 card was replaced after the original one was damaged due to an electrical overtension...
I can connect to the ecu now via tuner studio and all output test mode functions work, but the problem is that i have no rpm reading;
I though it was R56 , replaced it with a new component but the issue was not solved;
Was should i look for next ? U8?
Is there any way to test the components to know which one needs replacement ?
Thank you
No RPM signal after ms3 replacement
Re: No RPM signal after ms3 replacement
If you have an scope. You just start at the stimulator with the rpm signal and follow it through the components until it stops.
Graduate of EFI University.
Thanks buddy,elutionsdesign wrote:If you have an scope. You just start at the stimulator with the rpm signal and follow it through the components until it stops.
Unfortunately I don't have a scope at the moment where I'm at;
Any suggestions of what the possible components may be ?
