fuel pump relay not working
fuel pump relay control in the megasquirt isn't working. i have tested the relay and pump all is ok i have identified that the megasquirt isn't switching to ground as it should for the fuel relay control. i did accidentally attach the positive and negative to the battery terminals incorrectly so i think this has caused the problem so if i have blown anything in the board what would it be and where would i find it
Re: fuel pump relay not working
Go to the Manuals, look for the schematics, then pick the correct board type (V2.2, 3.0. 3.57). You will find the circuit with the components identified and a board layout.
Graduate of EFI University.
