Megasquirt 2 HEI tach input
electro1989
Post by electro1989 »
New ms2 having issue with rpm jumping. Have HEI mod with opto tied to 5 volts with 390 ohm resistor. RPM jumps from 1000 to 2500-6000.
I have scope of tach input and output of Opto to MIcro. Looks like it not switch correctly. This is not a GM module it a aftermarket module. Could this be the reason that the signal has a lot of noise. I am using a shielded cable to Tach signal. Set for falling edge.
Re: Megasquirt 2 HEI tach input
Post by Matt Cramer »
Is this a computer controlled HEI module, or are you triggering off the coil negative?
electro1989
Triggering of of GM HEI tach signal . Its mechanical/vaccum unit. So I am not controling the ignition, that the next step after I get fuel only working good.
Don't use the HEI mod for this - it is only for the computer controlled HEI. Instead, set it up for coil negative triggering.
electro1989
I am using a 8 pin gm hei module. Coming off the tach output. So it would be best to go of the negative coil instead with hardware set up for coil?
By the tach output, do you mean the wire that drove the factory tach (which connects to the coil negative) or the "R" pin of the module?
electro1989
Factory tach output.
Use the R pin instead.
electro1989
Switch to neg coil. Set up board for coil input. Megasquirt
operating great now.
